I took off the wheel and took a couple pics looking down at it that I hopefully will be able to post (I know, it's filthy). You will see it has a couple grooves that go around the circumference.
So my question is whether it is normal for what I assume is a spacer to stick out as much as it does, about 3 mm to flush with the seal (see pics attached). The spacer on the other side also has about a 2mm gap. Both are wedged in pretty tight and it seems to me the spacer on the other side used to come out pretty easily. I had the thought to try to tap them in with a rubber hammer but I wanted to ask if that was warranted and advisable. I've been known to make bad situations worse in this arena.
Thanks,
Jim
http://s1221.photobucket.com/user/duclad/media/IMG_0388_2.jpg.html?sort=3&o=2
http://s1221.photobucket.com/user/duclad/media/IMG_0392_1.jpg.html?sort=3&o=1
-Jim
'93 MC21
