  • NSR250 Forums Index ‹ RS250R Discussion
NX5 needle size
TomB
NX5 needle size
Mon Jul 17, 2017 9:56 pm » Post: #1 » Download Post
I have a pair of R1268N 1456 needles in my NX 5 carbs. Can anyone tell me which needle is (one size) richer than this? The part numbers are in the manual, but it's not obvious to me which is richer and which is leaner. I want to try a needle which will make the mixture richer between half and three quarters rpm.
Thu Jul 20, 2017 8:11 pm » Post: #2 » Download Post
From the NXA manual...
HRC wrote:
Jet needle 3366 needle clip position 3 equal jet needle 3466 needle clip position 3.5.
3466 is thicker (leaner) than 3366, hence needing to lift it half a clip to equal 3366.
Therefore a 1267 is thinner (richer) than your 1268.
The needles get thicker (leaner) as the number (and part number) increases. This is the same convention as the HRC NSR250 and RS250 NF5 needles.
The NSR250 TT-F3 manuals and NF5 parts manuals used to list the needle sizes in the notes section. I don't know why they stopped doing it in the later manuals.
TomB
Fri Jul 21, 2017 5:55 am » Post: #3 » Download Post
Thanks Andy. Do you have any in stock? I'll buy 2 if you have.
Fri Jul 21, 2017 1:23 pm » Post: #4 » Download Post
Sorry, no. Best bet would be Steve Patrickson I expect. Or Allens Performance.
Allens will normally have them with you next day.
