Decarbonise carbon endcan
Jarrodlim
Wed Sep 06, 2017 2:10 pm » Post: #1 » Download Post
Hi,
Does anyone here have experience with decarbonizing carbon endcan? As there are rivets on the endcan, I'm afraid if I remove and change the wool I would damage the integrity of the carbon tube, whereas if I were to use heat/fire to burn out the excessive 2t inside my endcan, I might also damage the carbon tube. Any help here would be very much appreciated!
Regards
Jarrod
Wed Sep 06, 2017 4:02 pm » Post: #2 » Download Post
Hi Jarrod, your best bet is to drill out the rivets and remove the endcap, that way you get all the old lagging out, ( presuming theres some in there ), it may seem a bit drastic and scary but take your time and it should go well, i have done this several times with no problem, if you accidently make the holes a bit larger, use the next size rivets on assembly.
