TPS sensor MC28, please help
mwarren
Tue Sep 26, 2017 1:20 am » Post: #1 » Download Post
I pulled the throttle shaft position key and have to reset tps sensor
What should voltage be set at or is done a different way
please help
simonmc18
Mon Oct 02, 2017 6:06 am » Post: #2 » Download Post
For the MC18 R5K this is what the manual says:
Throttle sensor inspection:
measure 16P coupler Bu/G and Y/R resistance. Std resistance (20deg C): 4-6K ohm
measure resistance between Y/Bu & Bu/G when throttle is fully closed to fully open and if each resistance value is exceeded then it is normal.
Std resistance (20deg C) Fully closed: 0-1.5K ohm (throttle stop screw loosen safely). Fully open: 4-6K ohm. When value becomes large, remove throtthle sensor 3P coupler connection and perform the above inspection at both sides of the sensor coupler terminals. If measured value is inside standard resistance value, then correct wire harness or replace it. If measure value is larger than the standard value then replace throttle sensor & sensor stay assy, joint, throttle shaft & throttle link arm as a set.
So I would say measure the resistance between the Y/Bu & Bu/G and adjust until you are within the correct range. This is assuming that the TPS work the same on all models, but it would help if someone could confirm this.
Tue Oct 10, 2017 11:29 am » Post: #3 » Download Post
On the MC28 there is an easy to follow procedure, however, you do need to be able to splice into the wires to check this, or make some sort of inline connector that allows you to measure the voltage.
First measure the supply voltage across the outside two pins of the 3P connector for the TPS. It will be 4.5V - 5.5V. This is "Va".
Now use the following formula to to find the required voltage for WOT (Vo) and closed throttle (Vc) which is used to set the TPS correctly. Measure between Y/Bu and Bu/G wires.
WOT:
Vo = Va x 0.786 So, if you measure 5V then 5 x 0.786 = 3.93V
Vc = Va x 0.1 So, if you measure 5V then 5 x 0.1 = 0.5V
It's pretty simple.
mwarren
Fri Nov 24, 2017 2:03 am » Post: #4 » Download Post
Thanks, got it set no error code. Now. And running. Excellent.
