Here’s our situation: When idle, the front cylinder is not working. Only 1 cylinder is working. The exhaust pipe is not heating up. But you can see some sparks from the spark plugs of the front cylinder. If you rev it to 3k rpm to 12k rpm, the front cylinder works. Thanks in advance!
