PGM3 fail
Ilpablito
PGM3 fail
Wed Feb 06, 2019 9:39 am » Post: #1 » Download Post
Hello
a friendīs mc21 is having problems.
The engine turn on but the valvles doesnīn move. I suppose that the problem is with the pgm,
what i can check?
is it easy repair it?
where i can send it to repair if i canīt do it by myself?
Thanks!
Wed Feb 06, 2019 4:31 pm » Post: #2 » Download Post
I would start by using the search option for powervalve motor and also provide some more info on what has recently changed on the bike, including the state of the battery
johnmax
Re: PGM3 fail
Thu Feb 07, 2019 5:01 am » Post: #3 » Download Post
My name is john
you must be see this !
and this is the advertising. https://www.car.gr/parts/view/12310083-electrics-ignition-electronic-control-unit-pc-hrm-hrm-hlektronikh-tupou-rs250-tt-f3-racing?lang=en
e.c.u. unit Only For
Honda nsr 250 mc21 for all models 1990-93. Honda nsr 250 mc18 r5k only. https://www.youtube.com/watch?v=OwljPTM-awE&t=26s
It can be placed as the original.
It snaps into the connectors of the motorcycle without cutting the original cables.
Manufactured in three versions
ΗRΜ Ι Normal 52 HP
ΗRΜ ΙΙ SP62 HP
ΗRΜ III TT-F3 72 HP
The final tests of the ECU UNIT occurred with a motorcycle dynamometer with adjustable carburetors using unleaded gas 95 octane rating, 20 Celsius and 40% humidity.
The motorcycle that was used: NSR 250 mc21-mc18 as manufactured by Honda without adjustments to the exhaust system, kit, carburetor etc.
Tests showed great flexibility, from 1.500 RPM engine speed up to 13.000 RPM with better acceleration throttle from PGM-II/PGM-III
Technical Characteristics:
Operating voltage from 10 volts up to 21 volts.
Not destroyed as the PGM-II/PGM-III.
Not destroyed by a burnt regulator.
Manages the RC VALVE/TPS/ELECTRO VALVES CARBURATOR/OIL PUMP.
I bought this e.c.u unit H.R.M.TT-F3, is amazing, everything is works perfect. He man has done great work!
From the 1500 rpm to6500rpm as if you had a better from one PGMIII HONDA.
From 6500rpm to 13200 as if you had pgm f3 NH3 (is a same).
this video is my bike https://www.youtube.com/watch?v=lYvgGIn_lEE
this video is my friend bike normal https://www.youtube.com/watch?v=5dgGEV0oNDs
