NC30 fork top on NSR
Sat May 22, 2010 8:07 am » Post: #1 » Download Post
Has anybody tried fitting NC30 (or 35) adjustable fork tops to NSR SE/SP forks??
A straight swap?
Sat May 22, 2010 9:07 am » Post: #2 » Download Post
Not sure I understand the question, the SP is adjustable?
Sat May 22, 2010 10:35 am » Post: #3 » Download Post
I'd like to see someone fit NC35 tops to NSR forks! Wink
Do you mean stanchions Tom?
Re: NC30 fork top on NSR
Sat May 22, 2010 11:01 am » Post: #4 » Download Post
racer38 wrote:Has anybody tried fitting NC300 (or 35) adjustable fork tops to NSR SE/SP forks??
A straight swap?
nc35? This is a joke...right?
RIGHT?
watfordhorn
1995 Honda NSR250 MC28
Sat May 22, 2010 3:05 pm » Post: #5 » Download Post
I think he means he has a knackered SE/SP top and he wants to find a replacement, are the VFR400 (NC30) the same?
Sat May 22, 2010 5:28 pm » Post: #6 » Download Post
Early mornings, late nights........ make me type funny.
Leigh's right, will VFR400 fork tops fit NSR ones to replace a set of buggered SE ones I have.
Sat May 22, 2010 6:10 pm » Post: #7 » Download Post
OK, I'm going to stick my neck out and say I reckon they are! The fork top (the cap) is the same part number 51454-KV3-781, but the twiddly bit for the pre-load and rebound is part of the cartridge so there's no part number available. It does look strikingly similar though, and I would be extremely surprised if it wasn't the same as the MC21SE/SP
Sat May 22, 2010 9:44 pm » Post: #8 » Download Post
Well I might take a punt on a set in the name of research...... watch this space.
Max
Wed Jun 03, 2020 9:55 am » Post: #9 » Download Post
racer38 wrote:Well I might take a punt on a set in the name of research...... watch this space.
Hi Racer
Did you ever try fitting NC30 caps on SE forks, I have the same issue.
Max
Fri Jun 05, 2020 3:52 pm » Post: #10 » Download Post
Hi Racer
Max
Wow this is an old post, I cant even rememeber what I did?!? So many bikes over the years, not to mention NSRs i's all a distant blur. Sorry Embarassed
Max
Fri Jun 05, 2020 4:08 pm » Post: #11 » Download Post
No worries Tom, me too!
I have Rick Oliver from the NC30 world looking into a replacement set of pins, we'll have a measure up and I will do a post 👍
Fri Jun 05, 2020 7:26 pm » Post: #12 » Download Post
Is this due to cost, or some other reason? You know TYGA make a set of fork tops, with adjusters that actually work?
Max
Sat Jun 06, 2020 6:43 am » Post: #13 » Download Post
Andy wrote:Is this due to cost, or some other reason? You know TYGA make a set of fork tops, with adjusters that actually work?
I had seen that Tyga make a fork top in other posts on this forum but I can't seem to find them on their website...but that is not my reason.
I am trying to return my bike to OEM where at all possible, money is not the driver on my restoration. For example, I recently installed Honda fork seals when a pattern set would easily have done the job.
I am happy to persevere and work out an issue to the end, it is part of the fun of being a home mechanic for me.
Sat Jun 06, 2020 11:14 pm » Post: #14 » Download Post
The adjustable tops can be found here: TYGA Performance TYLY-1038 (I won't link to the gawdy blue/red versions!)
The "bolt" (the outer part of the fork top) is the same part number between NC30 and MC21, but obviously the adjuster is part of the damper/cartridge assembly. However, if I really had to take a bet on it, I'd guess the NC30 adjuster is just as useless as the MC21 unit, and therefore likely [relatively] interchangeable. I imagine the only thing different will probably be the adjuster needle profile, but given that OEMs [at least back then] don't want you to adjust the suspension outside of a rather controlled range, it won't make much of a difference.
Max
Sun Jun 07, 2020 6:11 am » Post: #15 » Download Post
Cheers Andy, I used your part number and found them here on Jap4 listed under fitment as NC30...
https://jap4performance.com/product/fork-caps-full-adjustment-copy/
