MC21 Exhaust bush removal
sami1
Tue Oct 20, 2020 2:04 pm » Post: #1 » Download Post
Hi all,
Could someone please tell me a reliable method to remove the exhaust bush pn 18353KV3830.
The middle of the expansion chambers secure to the bottom of the chassis through this part.
Any info appreciated.
Sami
daz680
Thu Oct 22, 2020 5:01 pm » Post: #2 » Download Post
I made a thick alloy washer with a slightly smaller diameter than the bush passed a bolt through it through the bush with a socket that the bush will fit in on the back of the frame with the bolt passing through the socket aswell. Then simply tighten the nut and it pulls the bush through the frame into the socket. Simple as that.
Fitting is the opposite, made a 10mm thick spacer 5mm larger than the bush, bolt through it all again an pull back into the frame.
sami1
Thu Oct 22, 2020 7:27 pm » Post: #3 » Download Post
Thanks, that’s very helpful.
