KISS limiter cut
dikafor
KISS limiter cut
Fri Nov 14, 2025 8:26 pm » Post: #1 » Download Post
Hello, everyone!
I'm thinking about to install a KISS limiter cut to my "new" MC21SE.
Opinions will be apreciated Rolling Eyes
Fri Nov 14, 2025 8:52 pm » Post: #2 » Download Post
KISS delimiter is plug and play, and easily reversible. However, it's just an expensive wire-splice, and nothing more. If you want a part you can just fit between the harness and PGM-III, and remove at any time, and you're happy to pay for the convenience, it's a good modification. Personally, I'd just do (and always do) the wire-splice.
https://nsr-world.com/nsr250r-tuning/nsr250r-ignition/
dikafor
Sat Nov 15, 2025 6:27 pm » Post: #3 » Download Post
Andy wrote:KISS delimiter is plug and play, and easily reversible. However, it's just an expensive wire-splice, and nothing more. If you want a part you can just fit between the harness and PGM-III, and remove at any time, and you're happy to pay for the convenience, it's a good modification. Personally, I'd just do (and always do) the wire-splice.
Thank you Andy for your comment. Cool
Sun Nov 16, 2025 12:45 am » Post: #4 » Download Post
When I first bought my MC21 (30 years ago!) and knew no better, I ordered a set of Ethos expansion chambers from Cycle World in Japan, and they recommended & supplied me with a KISS delimiter at the same time. A few years later, once the wiresplice was "discovered", I took the KISS delimiter off and did the splice, and have been doing so ever since.
In my personal opinion, the KISS delimiter is a great, tidy, plug'n'play [easily reversible] option for anyone who doesn't want to cut into their harness. Although I mention it in the ignition tuning section of the Main Site, I never advocate an M-max box, as M-max are deceitful.
