MC28 headlight
kentishracing
MC28 headlight
Fri Jul 07, 2023 6:33 pm » Post: #1 » Download Post
Looking for help. the headlights are no working on high or low beam. all other lights are ok. Brake, tail instruments.
voltage at the fuse. Both relays check ok but only voltage on black/red wire
Diode checks ok but no voltage on any terminal for the diode. no voltage at the headlamp bulbs.
what to check next?
mc 28
Mon Jul 10, 2023 9:16 pm » Post: #2 » Download Post
Hi there you are aware the mc 28 lights will only work with the motor running ?
kentishracing
MC28 headlight
Wed Jul 12, 2023 6:00 pm » Post: #3 » Download Post
Hi Johnnymac
I know this sounds ridiculous but I didnt know until a couple of days ago. I have a whole lot of different bikes but none that have this quirk. From a mechanical sense I am ok being an ex 125, 600 and 1000 mechanic in BSB so I am a little embarrased by raising this question.
Thank you for taking the time to respond it is appreciated.
