Hello from sunny Brisbane, Australia. I've got a MC21 SP that I've had sitting in the garage a few years. It's an absolute hoot to own and ride!
It has developed a bit of a quirk recently. At low revs/idle the bottom cylinder is dropping out. I've just serviced the carbs thinking that was the issue and it has made no difference at all.
I've replaced the plugs on both cylinders.
It has aftermarket coils that the previous owner put on there, I'll test those later in the week.
Everything else is pretty stock.
Keen to find out if anyone else has had similar issues and what you've found to be the issue/solution?
Swap the coils over to see if the problem follows it to the other cylinder. I’d also find yourself a pair of genuine coils , I had aftermarket ones fitted by a previous owner and when one failed it took the PGM unit out (several times) it tested fine as well.
Other than that check your wiring and connectors to the coils.
Hate to pee on your parade, but it could be worn crank seals, especially if it's been sitting a long time unused, causing the seals to go dry. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
