Replica nsr?
Babafan1972
Replica nsr?
Mon Dec 25, 2023 8:45 pm » Post: #1 » Download Post
Hi, the rarity of NSR250's makes ownership rare.
Could a replica be built up from MC19 and MC22 parts?
The recipe could follow these parts;
Mc19 frame and tank
Mc22 forks, wheels, brakes, trailing arm.
Aftermarket Nsr250r fairing
Digital dash
CR500 motor swapped ratios
Cad designed cone power pipe
Would this combo work?
Mon Dec 25, 2023 11:23 pm » Post: #2 » Download Post
Interesting question
I think a genuine NSR would still be cheaper, handle far better and more importantly be reliable
And when your finished all you’ve achieve is a mongrel / faux that would be hard to sell on and never get close to returning your investment.
And without being rude a 500cc single isn’t a replica, it’s a whole different beast
Personally I think you’d be better of putting an RD350 motor in a TDR set up
Thu Dec 28, 2023 2:22 am » Post: #3 » Download Post
Hello "Babafan1972", and welcome to NSR-WORLD.
I think it could be done, but I can tell you two things for absolute certain... (A) it will end up WAY more expensive than an MC16 or MC18, and probably even an MC21/28, and (B) it will shake itself to bits!
A CR500 transplant has been attempted a couple of times over the years, and it just doesn't work. Not saying that the implementations I've seen couldn't be more refined, but the nature of the motor just doesn't really lend itself to a "road racer" configuration. It's rather harsh, vibrates a lot, with a low peak RPM.
The exhaust would take a lot of work to get something even remotely suitable "hidden" within the bodywork. Again, something that could probably be done if you have the required skills, but definitely not easy, and it's not as simple as changing the "shape" of the exhaust to overcome the characteristics of the MX motor, to make it more akin a road racer. You have to look at port heights/timing, port shape, combustion chamber design, compression ratio, ignition timing. Remember too, the CR is "piston ported", with a cruder RC Valve, that's much more off/on in its power delivery.
The CR motor has solid engine mounts, further adding to its harshness in a street bike chassis.
Bear in mind that a CR500 donor bike is itself becomming more and more expensive too. (You're better off restoring the CR and selling it, than wrecking one for the motor, in my personal opinion.)
Unless you already have one lined up or in storage, I think you will also find an MC19, certainly an MC22, is rapidly appreciating in value too. I think it's going to get very expensive, very quickly, but good luck if you take the build on, and we'd love to see how you get on.
