So I got some, sadly not from Performance Engineering which is where I should've got them, but on e-bay I think...
Anyway....here's the differences...note you can flip the HRC plates so it changes the geometry. To be honest I'm not sure which way to go. #1 or #2. I don't want to do anything that will change the stance so much that components start interfering with each other.
It's clearly not an exact science because I'm free holding the camera but I think you get the idea. It looks like Position #2 throws the swingarm down the lowest thus raising the backend the highest.
Stock Plates
HRC Plates Position #1
HRC Plates Position #2
