What's the easiest / safest way to remove the water pump mechanical seal, I don't have access to a hydraulic press and really don't want to be knocking out with a hammer and damage the casing.
any ideas / help would be appreciated.
Bearing removed no problem with a puller, just the mechanical seal is being a challenge
Mark
Update, as soon as I posted this, a little heat and out it popped!!
