Hi All
Can anyone recommend a good quality Puller that is both strong/thin enough to remove the Primary Drive Gear please?
I have a 3 legged Puller, but unfortunately, it is a bit too thick to go behind the Gear sufficiently and I don't want to end up chipping one of the Teeth. Additionally, I am a little unsure as to how thick some of the advertised ones are so if anyone has a suggestion I would be very grateful.
I take it that there is a lot more room to get a Puller behind the Primary Drive Gear if the Crankshaft is removed?
Many thanks
Philip
