Water Pump Seal Order/Direction: MC28
Dana
Mon Feb 16, 2026 3:21 am » Post: #1 » Download Post
In case you're here searching for water pump replacement on an MC28, hopfully this photo can help. I don't own an MC21 or older models, so I can't speak for them.
The oil seal should have the spring part facing toward the bearing.
Hopefully it's captured here in photo link. Obviously the crankcase separates the oil seal from the bearing.
The T2R kit looks great! Comes with everything except the impeller!
Hope this helps!
Dana
Seal Order: https://drive.google.com/file/d/1wdN7gDxUi8arsCWbHlgkVnMzrXcZSZMJ/view?usp=drive_link
T2R Replacement Kit:
https://drive.google.com/file/d/10hqBRiDcwAaPzllS_abyhC6StipQMdlX/view?usp=drive_link
Admin edit: I pro-actively hosted these images for your convenience, to ensure they are always available on the forum. (I've seen many instances where images are "lost", for example, those previously hosted on Photobucket, when they switched to paid hosting. I have PM'd you to check that you are happy to have these images duplicated on our server.)
2016 Husqvarna 701SM
2021 Husqvarna FS450 supermoto
1995 NSR250r MC28
Mon Feb 16, 2026 11:42 am » Post: #2 » Download Post
Excellent clarification! Thank you, Dana.
