neutral
dark8
neutral
Tue Jul 19, 2005 7:15 am » Post: #1 » Download Post
is everyone else's neutral really hard to find or is it just my bike....
i've been told its easier to find when coming to a stop. everytime im at the lights i cant get neutral until the lights turn green...hahaha...
is having the clutch in at the lights for about 3-4mins detrimental to dry clutch?
iom
Re: neutral
Tue Jul 19, 2005 11:05 am » Post: #2 » Download Post
Neutral should not be a problem if the clutch cable is correctly adjusted and the plates are all in spec'
As to the question having the clutch in at the lights for about 3-4mins detrimental to dry clutch?
YES!!
Dry or wet clutch.
Especially on the dry clutch!
It will wear the fibres prematurely and risk warping the steels.
Tue Jul 19, 2005 12:25 pm » Post: #3 » Download Post
You think?
I'd have thought it would just stretch the cable. There's no friction going on if you have the clutch properly adjusted...
dark8
Wed Jul 20, 2005 9:07 am » Post: #4 » Download Post
so if i cant find neutral must be problem with the clutch?
hmm...but if i cant find neutral at the lights im gonna wear out my clutch...that sux -_-!
Wed Jul 20, 2005 9:18 am » Post: #5 » Download Post
No, you shouldn't. What we're saying is that the clutch probably needs adjusting.
lossa
Wed Jul 20, 2005 9:36 am » Post: #6 » Download Post
hi i had same prob on my rs164, what i did is moved the gear lever 1 notch down so that i could get my foot under with more pressure this cured the prob and neutral came very easy after that.
iom
Thu Jul 21, 2005 5:34 pm » Post: #7 » Download Post
Dave Ett wrote:You think?
You will normally get a minute stretch in a new cable after which it won't get any worse.
You can get a small amount of disc flutter even when the cable is pulled in, which causes heat build up due to friction.
It is also in an unnatural state with the clutch springs coil bound and the lifter bearing under load. The end of the clutch lifter rod can also get hammering off the ball bearing.
Next time you watch a Moto GP see how long the riders are sat on the start line with the clutch pulled in.
It won't be for more than about 5-10 seconds max.
If the clutch is all ok and the gearchange is set ok as suggested by "lossa" then another cause could be a worn selector fork.
Hope you managed to get it sorted "dark8"
dark8
Fri Jul 22, 2005 3:15 am » Post: #8 » Download Post
thanks guys
when you say selector fork are you meaning the gear shift lever? that is a bit bent, and i have experimented with changing to neutral while the bike is slowing down (ie not stationary) and it has seemed easier. I will get the clutch cable looked at as well. Thanks guys
invigiator
Fri Jul 22, 2005 4:13 am » Post: #9 » Download Post
If you are completely stationary with brakes on you may have trouble finding neutral. Most people engage neutral before the bike is completely stopped. If you do reach a complete stop then let off the brakes and just move the bike forward under you.
With gentle pressure on the gear-lever, you literally have to move the bike about 1cm and it'll drop right into neutral.
MC28 SE -sold-
MC21 with RS250 engine -for sale-
MC21 race bike -soon for sale-
