...so just got the bike rolling . It s jetted super rich ( it drinks up fuel like never before ) and I rev it up to 7k to be as kind to it as possible now that its still fresh.The problem is that when i brake or when it revs below 4k i get a noticable fall on the headlight's lighting power.Any suggestions on what to look for ?
Check the voltage accross the battery. It sounds like the battery is dying or the system is not charging it properly. _________________ MC21SP Plaything
With the bike at about 2000 rpm, the battery should read about 13.5-14.5 volts. Any higher and the reg/rect isn't doing it's job. Any lower and it could be the reg/rec, the battery or the alternator.
With the ignition off, the battery should read about 12.5 volts. Any less than 11.5 and it's due a sesion on an Optimate, or replacement. _________________ MC21SP Plaything
