92' MC21R front wheel in red with both spacers, spindle and bolt.
EBC prolite discs with 4mm thickness (not had much use)
Wheel bearings are good as are the oil seals.
Bridgestone BT010 fitted, not been used much.
Is it worth 60 quid to anyone??
Bear in mind i won't post it to you, so you will have to collect it. _________________ After years of moaning about immigrants now i am one...
