Where is the speedo cable mounted on the NSR 250 mc21? I bought a wreck I am fixing, and I cant seem to find where the speedo cable is mounted. I have no cable connection point on my front wheel.
Hi the speedo fixing location is through the plastic cover on the front sprocket. You should be able to see how it locates, that is if you have the cover on your wreck. _________________ Hmmmmm!
Easiest might be to follow the cable back from your speedometer to where it mounts near the front sprocket, assuming all parts are still there!
-Jim _________________ -Jim
'93 MC21
