Speedo cable
Guest
Speedo cable
Mon May 03, 2004 7:15 pm » Post: #1 » Download Post
Where is the speedo cable mounted on the NSR 250 mc21? I bought a wreck I am fixing, and I cant seem to find where the speedo cable is mounted. I have no cable connection point on my front wheel.
DMB
Mon May 03, 2004 7:30 pm » Post: #2 » Download Post
Hi the speedo fixing location is through the plastic cover on the front sprocket. You should be able to see how it locates, that is if you have the cover on your wreck.
Hmmmmm!
Jim
Mon May 03, 2004 7:59 pm » Post: #3 » Download Post
Easiest might be to follow the cable back from your speedometer to where it mounts near the front sprocket, assuming all parts are still there!
-Jim
-Jim
'93 MC21
