I wanted to look into this. I am pretty sure I've seen various hondas (CB,CBR,etc.) in tokyo with gold brembo calipers. I believe spacing is 65mm for brembo and I had measured ~62.5mm on MC28 lower mounts. anyone confirm this?
So - can anyone confirm wether the Brembos will bolt straingt onto a MC28
If MC28 is 63mm, how can 65mm Brembo fit it ? Adapter plate
If they do fit - anyone know how much £ and how much better than standard gear...
Dudes chill, i was just going by what i was told in the RVF section on 400greybike, i read on there that 65mm Brembos bolt straight onto the RVF and with the RVF having the same bolt spacing as the MC28 i assumed...
i bought the adaptor plates from Jamies site to fit Brembos onto my 21 i measured the pistons and the Brembos are about 1mm bigger and weighed the calpers and over all the Brembos were a wee bit lighter, so not a massive performance upgrade but they will look nice
found out some more info : you are right Brembos will not bolt directly onto a MC28 but Brembo make an adaptor plate for the RC45 so that you can fit 40mm pitch Brembos to it, and with this adaptor Brembos on a 28 as (i am told) the PCD is the same as the 45.
sorry for the confusion. _________________ MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
Don't let it happen again or Tom Hofton will come over to your house and give you an atomic wedgie. (Mind you there's a hell of a difference between a standard wedgie and the atomic variety).
I have this brilliant idea of hogging out the mount hole(s) on the lowers to make 65mm pitch brembos fit. anyone have a lower to donate to science?
i think the holes on the bottom of the fork leg are threaded so you would have to tap them again. _________________ MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
MC28's have the threads in the calipers, and the forks are just a straight hole with no threads. MC21's are opposite. _________________ Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
