hello again ya'll yeah, my nsr has no oil pump so i will be premixing it. i usually run 32-20:1 in my long rod RD, what is the recommended amount for the nsr? i'd rather be safe than sorry, i like motul products, if other recomendation please advise and since we are on the subjet of fluids what antifreeze ratio should be in my radiator any specific's here also would be greatly appreciated....THANKS AGAIN.. _________________ DAYTONA SPECIAL,74 RD350 LONG ROD, 2 RD200 ELECTRIC'S,88 NSR 250RG, MICRO SPRINT CAR W/CR 250 ENG
I agree with charles. I also run mine at 32:1 using motul, and damm does it smell good I use engine ice in mine but if you use antifreeze, mix it at 50/50 to get the best cooling and antifreezing properties. Hope that helps. _________________ To much HP is barely adequate!
good i am on the right track any jetting advice? sea level _________________ DAYTONA SPECIAL,74 RD350 LONG ROD, 2 RD200 ELECTRIC'S,88 NSR 250RG, MICRO SPRINT CAR W/CR 250 ENG
