My question is. can i use normal 4t oil in the gearbox or does it need to be motorcycle transmission oil.
The reason i ask is that my dad has sh*t loads of Castrol GPS 10w/40.
Also is there anything else i should be aware of with the engine swap? _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
had a look at the oil situation and there appears to be some very clean (not like its going to get dirty) gearbox type oil in it. I think I may just leave it as the engine has had a very recent rebuild. _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
