MC 21 R spring rate
laurent acrobike
MC 21 R spring rate
Sun Apr 09, 2006 7:12 pm » Post: #1 » Download Post
I have a problem with my fork. Sad I fitted some hyperpro R6 spring in it with #15 oil (120mm level) and the result is not so good. Because of the variable spring I can't set the preload correctly. the rebound is too heavy (slow) in the first 50mm
So I want to order a set of constant spring but I don't know witch rate. my weith is 62 KG naked and it's for racing use only.
I think .700 or .750 kgf/mm will be OK but I want to be sure. Question
watch my www
