?'s for NSR Motor Guru's
Steve C
Tue Apr 25, 2006 7:22 pm » Post: #1 » Download Post
Pic 1. I'm taking out the kick start gear. Want to know if anyone has taken the gear I'm pointing to in the first picture and cut the center out and just used it as a spacer for the shaft it is on??
Pic 2. The gear on the triangle plate what is it for? The bolts on mine where very hard to get out is that normal??
pic 3. I have been trying to clean up the intake track and was wondering if the area behind the crank should be smoothed out as well ??
The pictures can be found at the link below bottom row mc21 motor?
http://photos.yahoo.com/rothmansmc18
Steve
rc46
Tue Apr 25, 2006 9:02 pm » Post: #2 » Download Post
answer best i can
the gear on the triangle plate is the water/oil pump gear, this will run the white coloured gear on the engine case, this is the water pump oil pump gear
anybody else for the other answers?
Wrench.
Wed Apr 26, 2006 12:48 am » Post: #3 » Download Post
Steve,
why dont you just get the HRC shift shaft hole plug? They are really cheap!
Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Wed Apr 26, 2006 3:27 am » Post: #4 » Download Post
Just take the gear off. No problem.
The triangle thing is the oil pump as already said and runs off the clutch. Leave that in situ.
