Hi All:
I am returning my MC-21 to street rim, and decided to do the wire splice. On the track, I ran the HRC harness with the HRC derestrictor, and some years back, when it was on the road, I used the stock harness with a KISS box. Both setups always worked perfectly.
Anyway, I got a little surprise when I stripped back the sheathing to check out the old street loom for the splice. It already  had 2 splices. The Dark Green wire running into the white plug is spliced to the Orange/Blue from the black plug. And the Dark Blue wire from the loom is spliced to Yellow going into the white plug. It almost looks like it was done at the factory. The wire is cut and stripped cleanly, and there are proper brass wire crimps, machine closed, on the splices. There was no sign of the splices from outside the loom.
So I have a dilemma. If I splice 12v. into the Orange/ Blue, it will also be run to the Dark Green wire. I don't know if this is OK or not. So if anyone has ever seen this splice, or knows what it's for, I'd appreciate any info you could provide.
Jim Mason
