I think Josh is looking for the actual shaft and not the seals. I don't think the shaft is sold by itself from Honda. I think it's an entire unit (pump) with the shaft.
Josh, if you have an issue with the shaft, you may just want to look for a used pump assembly as Honda doesn't list the shaft as a part by itself. _________________ Charles Gallant
