Torque Spec's?
rc51paul
Torque Spec's?
Fri May 12, 2006 2:44 pm » Post: #1 » Download Post
I can't seem to find the torque spec for the intake boot bolts anywhere. Anyone know or can point me in the right direction? Thanks for the help.
To much HP is barely adequate!
cgallant
2001 Honda RS250
Fri May 12, 2006 4:06 pm » Post: #2 » Download Post
Being a 6 mm bolt, it's normal torque setting is 0.8-1.2 kg-m.
For these bolts I generally don't use an actual torque setting and just expect it to be good.
I actually set the bolts while doing a leak down and make sure they are set so nothing leaks. This you will find is good to do if the intake boot is warped.
Charles Gallant
rc51paul
Sat May 13, 2006 4:51 am » Post: #3 » Download Post
Thanks Charles that helps out alot.
