Do tyga pipes still use the brass seal? can i reuse the seal and does anyone sell new ones. carbon fiber tyga power reeds come with extra support pieces but no order detail and do i still use the stock steel brace. i wish tyga wasn't so busy anyone help thanks
Yes the Tyga pipes use the brass seal. If you don't have new seals you can put red silicone on both sides of the seal and put it back in. It will work for a while. Also put some silicone on the flange before sliding the pipe on.
