piston identification
lilblakcooper
Tue Aug 01, 2006 7:29 pm » Post: #1 » Download Post
how do i tell if i need a "b"piston or what when the pistons i have taken out of my engine do not have any markings on them.
and do i buy my mc28 piston kits from tyga which i am led to believe that they will fit my mc16 engine.
please correct me if im wrong.
Tue Aug 01, 2006 9:06 pm » Post: #2 » Download Post
There should be a marking on the rear base of the cylinder saying A, B or C. You can use this marking as long as the cylinder has never been replated. If it has then you need to measure the cylinder bore (with a bore guage), work out what clearance you want to run and then calculate what size piston you need to order.
Jeff SZ
Tue Aug 01, 2006 9:38 pm » Post: #3 » Download Post
Here's how to match up cylinders and pistons.
A Cyl = B piston
B Cyl = No mark piston
C Cyl = D piston
lilblakcooper
Tue Aug 01, 2006 9:54 pm » Post: #4 » Download Post
thanks guys now just to see if my local honda dealer can get them for me!!!!!!!!!!!!!!!!!!!!!!!!!!!
