Everytime I hit some bump my fuse blows so my dashlight/indicators dun work. I stripped the computer/leads, see no visble shorts and used electronic contact cleaner on the connections, could it be my turn relay.?
You're going to have to check all the places the wiring loom runs close to the frame, as it's likely that some insulation has worn through and is causing a short.
Personally, I'd disconnect both leads from the battery, then do a continuity test between each pin of the plugs and the chassis to find out which one is causing the short. _________________ MC21SP Plaything
