Guys just want to clear things about what I read in the tuning section..
If you turn the airscrew clockwise will it richen the mixture or make it lean?
pls expain this clearly becuase from what I understood, if you open the airscrew ( counterclockwise ) it will make it the mixture richer.. is that correct?
