whilst I am mustering up the courage to buy another 250cc two stroke that I will not have time to ride, I would appreciate if someone could help clarify the engine situation.
- Are all engines marked MC16?
- which engines are compatible across which models - bolt in, plug in or more complex?
- Which engines have cranks that are easy to rebuild - do they all have the press on covers like RS250?
- do all engines use the same centre bearing with integral seal?
- Similar to 2 above, but electrics
- Which ignition pickups and alternators fit which engines i.e. tapers, mountings
- which engines and alternator sets can be used with which electrics
- which clutches and gearbox are compatible across which models - are they all the same
- are the cylinders the same across all models - do the same heads fit apart from round or octagonal, and exhaust pipe flanges in the same place?
- are teh reed cages/rubbers same across all models
- any useful information I may have forgotton
Cheers to all who help, Vincent
NSRless again...
