coolant leak help?
tiago
coolant leak help?
Sat Jan 20, 2007 10:06 pm » Post: #1 » Download Post
ive got a coolant leak on my 18. the coolant is dripping from a tiny drain hole near the pump. whats causing this? Question
Sat Jan 20, 2007 10:52 pm » Post: #2 » Download Post
Quite possibly a dead water pump seal. The seal kit is still available from Honda and will probably take you about an hour to fix.
You'll need a clutch cover gasket and water pump gasket too, as the case needs to come off to do it. May as well replace the transmission oil as well, while you're at it! Smile
tiago
thanks!
Mon Jan 22, 2007 10:51 pm » Post: #3 » Download Post
Very Happy thanks!
