I'm trying to find the part number for the alloy clamp that goes onto the main splined shaft that comes out of the gearbox on my 21... the clamp that joins onto the shift shaft. I must be stupid because i cant find it in the parts manual! also where would be the best place to get this part, mines so loose its started missing gears thanks
i hope that made sense, i can get a picture if noone knows what im talking about.. _________________ Hesitation is Fatal!!
Found it, it's under kikstarter/levers in the parts manual, although theres 5 different ones depending on model (I assume it's a 21) _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
ok so the stupid question for today is what model is it? i cant figure it out...... my frame number is mc21 101776 thanks _________________ Hesitation is Fatal!!
When you open the parts manual and click on 1990 - 1993 theres a list of models with standard paint schemes and associated frame no's although I cant see there being much difference between them. _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
