carb question
richie
carb question
Fri Feb 09, 2007 8:11 pm » Post: #1 » Download Post
hi, will a set of MC28 carbs fit on an MC18 R5K ? am i right in thinking i can use MC21 carbs on the R5K if i use a jet kit, blank off the power jet etc ?
having carb problems but cant track a set down for the R5K. been offered a set for the MC28.
any help much appreciated.
richie.
beakergixer750cc
Fri Feb 09, 2007 8:33 pm » Post: #2 » Download Post
Hi Rich,i'm not sure if mc28 carbs fit,but you should be able to fit mc21 carbs without using the jet kit on your 18 if using air solenoids no need to block power jets either me thinks
richie
Fri Feb 09, 2007 9:11 pm » Post: #3 » Download Post
thanks m8, sounds promising. Smile
