Is anyone up for it on 23rd april,organised by focussed events for £139.
I'll be taking me gixer as back up just in case i blow up the nsr i'll stick some new rings in before i go.How long do i need to run in a new set?
cheers Rob
ive chucked me other engine in my newly rebuilt chassis,just to see how she handles,just waiting for me engine back from you mate
Have you got any piccies for us yet?
It's almost done, cases are finished as is the crank, everything is measured up and its been built up dry. I'm just waiting for a couple of bits to come and it will have its final build. _________________ If I have to take the carbs off once more...
I'll probably ride her down to you when engines finished,get you to swap engines over and set her up then ride home again.
May as well get you to sort out spare lump as well,i'll keep her a 250 though
what do you think?
I'm going to that as well.If own you had said about the hole before I spent £22 on a ticket _________________ Harley Davidson is the worlds most efficient way to turn petrol into noise without the harmful side effect of horsepower.
