A few people on here, (myself now included!), have had problems with the flywheel ignition pick ups. They`re the two units outside of the flywheel rotor. The wiring to them can get damaged as it enters the plastic case of each unit.
They`re easy enough to check, have to take the lower fairing & genny side cover off. 4mm Allen key to remove the mounting bolts for the pick ups.
