Clutch adjustment
mattc
Clutch adjustment
Thu Jun 21, 2007 10:33 pm » Post: #1 » Download Post
When i have the my mc18 in gear with the clutch in (engine not running) its dragging a lot - ie pushing the bike turns the engine over a bit.
Is the only adjustment the one under the clutch cover? I've wound this full travel both ways and dont seem to get any improvement.
Does this point to worn friction plates?
Is pulling the clutch off an easy job for someone thats never done it before?
fenton
1990 Honda NSR250 MC21
Thu Jun 21, 2007 10:41 pm » Post: #2 » Download Post
is the single ball bearing still in there
j911brick
Fri Jun 22, 2007 12:39 am » Post: #3 » Download Post
What about the adjustment at the clutch lever?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Fri Jun 22, 2007 1:37 am » Post: #4 » Download Post
Try changing your oil.
Both lever and mounting adjustments just control freeplay, not clutch actuation.
mattc
Fri Jun 22, 2007 6:34 am » Post: #5 » Download Post
Where's this ball bearing?
I'll give the oil change a shot see if it helps, Thanks for the replies guys
HRC 6968
Gearbox
Sun Jun 24, 2007 8:49 am » Post: #6 » Download Post
Fill the Dirty Gearbox up with fuel and give it the arsenal clean, found that a Fuel Bath does the World of good for freeing up sticky oily grease.
Worked a wonder for freeing up my gears, meshes and shifter cylinder,
Embarassed
HRC Is Getting Expensive
Its' like the AIR is crappy at Ground level.
