Sorry, sorry, and sorry.
I know there are plenty of posts about pre-mix and jetting but after browsing alot of them, I'm still not too sure about what I should start with. I'm mostly stock so hopefully this should be easy:
Stock pipes and chambers
Stock airbox & filter (with 4 big holes drilled)
Powerjets are retained
lost the injectors so full pre-mix
Did both wire splices
Located pretty close to sea-level (Virginia, US) but pretty humid.
It's a track-day bike but on a tight course so midrange will be welcome.
The carbs right now have 42 SJs and 142 MJs and stock needles (no washers).
The bike boggs on the low end, especially riding from a dead stop, but the top is great!
Should I go down to a 40 SJ and maybe go up to 145 MJ, and maybe even add a washer to the needles?
Thanks in advance and again, sorry for the millionth pre-mix jetting question but I couldn't find a topic that matched my scenario close enough...
Jae (PekingDuc)
