vhm heads
owo1
vhm heads
Thu Jun 14, 2007 4:53 pm » Post: #1 » Download Post
has enybody tried vhm heads . i will mostly use my mc28 on the road.
with odd track day . are there power gains to be had ? plus reliability ?
Thu Jun 14, 2007 6:41 pm » Post: #2 » Download Post
I don't think reliabilty will be any issue. As always, that's always down to setup and the condition of all the other components as a package.
As for being worth it, well I haven't tried them myself, but there are only two main areas the NSR motor can benefit from a redesign compared to the RS250 motor, and one of those is the head design.
I personally think that VHM (or similar) heads will bring a full spec MC21 motor to within just a gnat's whisker of the output of an RS250. A full F3 motor is close, but it will never quite be there because HRC made sure it can never be quite as good as the GP motor! Smile
As for whether it's worth it on a road bike? Well that all depends on if you are going to submit it to Posers World really! Laughing
jkolewski
Fri Jun 15, 2007 10:49 pm » Post: #3 » Download Post
Bolted them on last night but wont be back out to the track for another 2 to 3 weeks after this weekend. I'll let u know.
1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
Mon Jun 18, 2007 1:32 am » Post: #4 » Download Post
As Andy says, it's all down to design.
The stock NSR heads are ok for basic shape, but they suffer in two areas. First being the squish clearance too big, and the second is the plug position.
The VHM NSR250 headsets reposition the plug to the centre of the head. This helps for complete combustion. However, in my opinion the squish is still a little loose at a shade over 1mm. They're 12.6cc volume which is good for pump fuel. If you reset the squish for 0.7mm (0.3mm thinner base gaskets) this would give you a volume of around 11.9cc, meaning that you'd have to run minimum 98 octane, or there abouts.
The VHM heads also offer better cooling (very slightly) and are more efficient, so I've found I could run leaner jetting. Be sure to check though before shuffling the brass.
Jeremy's got NSR300 heads, with inserts for both pump fuel and rocket fuel, so it'll be good to see how he gets on. Tread carefully brother Jeremy!
cgallant
2001 Honda RS250
Mon Jun 18, 2007 2:21 am » Post: #5 » Download Post
The other nice part about the VHM heads are you can get a blank insert and get it machined to your specs. So basically you can get the shape and squish you want.
Charles Gallant
