I'm in the midst of trying to fit a 300cc kit. I noticed that one of the barrels is marked "D", and t'other "C". My pistons are all marked "B".
Do the piston and barrel need to be matched the same way as a 250cc set would be, or is the D and C marking designed to differentiate between the front and rear barrel? _________________ If I have to take the carbs off once...
