help
modgeneration1986
help
Thu Jul 12, 2007 12:09 pm » Post: #1 » Download Post
hello
im having problems with my wiring loom on my mc21
the problem im having is that i am getting no power to the powervalve servo from the wiring loom but everywhere else on the bike works fine. The servo itself works fine when giving 12volts from the battery. The bike runs as normal apart from the obvious powervalves.
if anyone has any suggestions it would be greatful
cheers
Last edited by modgeneration1986 on Thu Jul 12, 2007 5:26 pm; edited 1 time in total
Thu Jul 12, 2007 1:36 pm » Post: #2 » Download Post
Assuming we're talking MC18 or 21:
The powervalve is controlled by the PGM unit mounted in the tail unit.
It may be that the circuits controlling the power valve have burned out - this is not uncommon, though usually this breaks the PGM unit completely and the bike will not run.
Best to unplug the powervalve from the loom until you rectify the problem, as the PGM may be repairable if the bike is still running.
I'd start the hunt by removing the cover from the PGM. Looking inside you will see lots of brown 'goo' covering the circuit board. If any of this shows discolouration, and burning then you have a problem!
modgeneration1986
Thu Jul 12, 2007 5:30 pm » Post: #3 » Download Post
the bike runs as normal. When the pgm is unplugged and the iginition switched on there is no power coming from or going to the powervalve servo. But every other plug has 12volts going to it when tested.
Thu Jul 12, 2007 8:06 pm » Post: #4 » Download Post
Dave Ett wrote:Assuming we're talking MC18 or 21:
I'll say it again then:
If you unplug it, how will power get from the PGM to the servo?
modgeneration1986
Fri Jul 13, 2007 10:06 am » Post: #5 » Download Post
i have taken my pgm off and it has gone pop Sad
thank you very for helping me out with my problem
kind regards Smile
Fri Jul 13, 2007 11:41 am » Post: #6 » Download Post
Ouch, not good news.
How bad is the damage - can you post a picture of it?
If the only part not working is the powervalve, I may be able to fix it...
modgeneration1986
Fri Jul 13, 2007 8:30 pm » Post: #7 » Download Post
ok cool, if you give me your email address i will send them to you[/img]
