I want to use an HRC Wiring Harness to my street bike (MC21) but I want to know if I can keep my rear and front lights, keep working in some way... Can some one knows, how this can be done... Or it is better to connect the HRC delimiter box with some modification to the cables straight to the standard harness...?
mixalisen
It would be better to leave your stock harness on and do the wire splice. Same end result but you keep all the lights etc. _________________ If I have to take the carbs off once more...
