Compression test
emerckx53
Compression test
Fri Oct 05, 2007 1:55 am » Post: #1 » Download Post
Could I please get a compression number for an NSR? My bike has 7K on it...I am going to check it soon...could I get a high and low range? Thanks...
Michael
'93 MC21 250sp Repsol "Doohan"
p0lariso
Fri Oct 05, 2007 12:51 pm » Post: #2 » Download Post
MC28 Cylinder head compression pressure 10.0 kg/cm2/400RPM
emerckx53
Fri Oct 05, 2007 2:58 pm » Post: #3 » Download Post
Thanks! any chance you can convert that to lbs? Or do most gauges read both? Thanks-
Mj
Fri Oct 05, 2007 3:45 pm » Post: #4 » Download Post
http://www.onlineconversion.com/pressure.htm
p0lariso
Fri Oct 05, 2007 7:46 pm » Post: #5 » Download Post
10 kilogram-force/square centimeter = 142.233 433 343 pound/square inch
Is this correct ? How do you do a compression test at 4000 RPM's ?
Fri Oct 05, 2007 7:54 pm » Post: #6 » Download Post
I think you will find he said 400 rpm
p0lariso
Fri Oct 05, 2007 7:59 pm » Post: #7 » Download Post
Sorry you are correct its 400 RPM
I have a nagging habit of adding zeros, escpecialy while invoicing Very Happy
nsr250racer
How About the MC21 ?
Fri Oct 05, 2007 11:29 pm » Post: #8 » Download Post
Is it pretty much the same compression on the MC21? 142lbs @ 400 rpm ?
FILOLI - Fight, Love, Live
j911brick
Fri Oct 05, 2007 11:59 pm » Post: #9 » Download Post
How do you get the 400 rpm?
james
Its not how fast you go...Its how you go fast.
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
http://members.rennlist.com/j911brick/rennlist3_002.htm
SLF-951
Sat Oct 06, 2007 12:45 am » Post: #10 » Download Post
With the kick starter Rolling Eyes Should be about that rpm to get em going ??? Plus with the other plug out ..... No problem
MC21
04 NSR50R
93 CBR F2
98 CBR F3 track bike
95 VFR750
89 FL400R Pilot
90 FZR 4/600
emerckx53
Sat Oct 06, 2007 2:28 am » Post: #11 » Download Post
Thanks to all........again, can anyone give a compression number that would indicate a cylinder that is tired? 130? 140?.......I have 12k on my NSR
