Float setting?
Alwyn
Float setting?
Thu Oct 11, 2007 3:31 pm » Post: #1 » Download Post
How do you set the float height to a certain given mesurement?
Thu Oct 11, 2007 7:58 pm » Post: #2 » Download Post
With a virnier caliper or with a Honda float hight tool.
Alwyn
Fri Oct 12, 2007 10:01 am » Post: #3 » Download Post
Thats all good 'n well Stephen but where do you make the actual mesurement?
Fri Oct 12, 2007 1:19 pm » Post: #4 » Download Post
From the float bowl face to the top of the float. the float needle must be unloaded though to get a propper measurement.
Fri Oct 12, 2007 5:38 pm » Post: #5 » Download Post
Very difficult to explain I reckon.
Alwyn
Fri Oct 12, 2007 9:51 pm » Post: #6 » Download Post
HA! Thanks guys. I WAS trying to figure out the symantics there for a bit but thanks for the pic Andy!
Pekingduc
Thu Nov 15, 2007 4:03 am » Post: #7 » Download Post
Sorry to bring back an old topic but after finding this and the link on Tyga's site, I still wanted to make sure I was headed in the right direction before I put things back together.
So... to correctly measure float height, per Tyga's instructions, you need to set the carbs at 90 degrees to make sure the float piston is not compressed? As in, do not measure the height of the floats when fully extended right? I gather the point of the 90 degree position is just to make sure the floats are extended as far out without engaging the piston so you could actually do this manually by moving the float until you see the piston engage too?
Thanks,
Jae
Thu Nov 15, 2007 4:07 pm » Post: #8 » Download Post
Think about what the float, float needle, and needle jet are trying to accomplish. Here are two more images to help you.
If that doesn't do it, take the bike to a shop!
Pekingduc
Thu Nov 15, 2007 6:19 pm » Post: #9 » Download Post
That works. Thanks Andy. I'm a visual kind of guy so I just needed to make sure the text and pics all matched up in my head...
Jae
Thu Nov 15, 2007 11:14 pm » Post: #10 » Download Post
Glad the diagram helped. I drew it (whilst sober, before Matt comments on the time of the post!) from memory, but I think it's fairly accurate.
Fri Nov 16, 2007 1:26 am » Post: #11 » Download Post
Andy was still sober 'cos he'd only just got out of bed Laughing
Fri Nov 16, 2007 6:21 am » Post: #12 » Download Post
I'll have you know I saw sunshine yesterday, and I'm seeing sunshine now!! Cool
