Topic says it. Just wondering how wide sp magtek's are? I know there not 3.75 and 5.5. I'm guessing 3 and 4.25 or 4.5. _________________ 1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
1998 RM 250 freestyle/motorcross
1998 Meathanol burning CR 500 AF super retard/motorcross/sand dunes/play bike
RS250 5.25" rear is the easiest to fit. As StephenRC45 says you do need all the HRC gubbins to go with it, but than can be sourced. Well some of it can. Or fabricated.
I've got TZ marvics in my bike. Rear's 5.25". It was an easy fit, just so long as you have a machine shop at your disposal
Front 3.5" rims are common on NC30/35 and bolt straight in. They're not Magtek's though. If you want magnesium wheels you'll need an RS front. Pretty much plug 'n' play, but will need a front spacer change.
If you have the knowledge, the time and the tools you can get anything to fit within the boundries of common sense.
Mine is a 5.25 RS wheel. Nothing needed changing apart from putting a different spacer in, and using RS250 sprokets... I ordered an AFAM one through Steve Patrikson. Still using the orginal MC21 caliper and bracket, and original MC21 disc, which is a direct bolt on! Good luck finding one though!! _________________ NSR300R - Why did i ever have a 250...
Now I thought all RS 5.25 magteks where a 4 bolt disk not the NSR 3 bolt job. Learn something new every day _________________ If I have to take the carbs off once more...
When I've made my first £million (which ain't gonna be this week!), my workshop will be fully fitted with CNC machining centre and lathe, and one of them there laser cutters. I'll keep my little lathe though 'cos it's blooming handy for turning little bushes up
StephenRC45 wrote:Now I thought all RS 5.25 magteks where a 4 bolt disk not the NSR 3 bolt job. Learn something new every day
It's not a Magtek but a Technomagnesio. I think Matt said it was an F3 wheel so maybe that's why it's a direct bolt on?? Matt? _________________ NSR300R - Why did i ever have a 250...
