Guys,
I thought I was done installing new clutch plates and for the most part I am.  However...  After putting everything back together, my clutch lever now has way too much slack and actually, when I pull it, the plates no longer move.  All the parts are back in the clutch assembly but I'm thinking that the slop is that actuator assembly that connects the cable to the clutch.  Not sure what this is actually called but are these easy to break/tweak?  I'm hoping that I can just unbolt it and replace/adjust but would appreciate any advice from folks who've touched this assembly before.
Thanks,
Jae
