Well spring is coming soon and i've got to hurry and fix my seizured 21.
Found 2 good barrels(H\C AND L\A) and now searching for the rest needed for the rebuilt.I have the heads kv3HRR and kv3LFR so i'm ok with these?
I was thinking to measure the exact diameter of the barells with a
micrometer and then choose the best piston to fit from the 3 stock's or do
you think it is too much and i should go with the standard information:
'A' Cylinder - 'B' Piston
'B' Cylinder - 'No mark' Piston
'C' Cylinder - 'D' Piston
